I took my 2002 Evinrude 250 Ficth DI to the Dealer to have a new water pump installed as preventive maintenance and they also installed a new fuel rail. I went for a test run when I got it back and the tell-tail was spraying water very hard ( not a steady stream like normal) and the motor vibrated between 1500 and 4000 RPM. I took it back to the Dealer and they hooked the laptop to it and we went for a ride. All showed normal and all they could tell me was that it was pumping too much water and not letting the motor warm up enough to burn all the fuel and fouling the plugs. They checked all locations for any blockage and found none and then called BRP for help. That was over a week ago and they are still stumped. Has anyone had or heard of this problem or am I the only lucky dog to get this one?
