Re: Throttle valve on cold start
Thanks for the reply. I have the manual, and understand the link and sync procedure. I'm more asking if the end result should be: at full fast idle, on a cold start, should the throttle valves open a little bit to assist in the start, or remain closed. The answer to this may very well warrant a link and sync. Currently, the valve remains closed. I have been having trouble on the cold start, and traced some ignition issues to a bad rectifier, and then a sticky leaking stator. New rectifier is in, stator is on the way. During all of the troubleshooting, I noticed the action of the throttle valve during fast idle. I couldn't find anywhere in the manual stating if the throttle should open up a little bit as the cam rotates with max fast idle. Thanks in advance.
