Re: When changing water impeller do I HAVE to drain the lower unit??
MOXIEBOY:
Sterndrives are different than outboards. On the outboards, the lower unit is a sealed unit (Gear lube is self contained), in a stern drive, the gear lube also goes from the lower unit up to the upper gears. So when you drop the lower unit, all of the gear lube from the upper gears will drain out. That means when you re-install the lower unit, you will have to add more gear lube and that means removing the lower plug on the lower unit. If it were me, I would go ahead and drain the gear lube, collect it in a container and if it's clean and not old, I would just put it back in after re-installing the lower unit.
HTH, Craig
