Hello,
I am considering buying a 2001 Trophy with twin Opti 150's. When I started the engines out of the water with a garden hose attached, both motors were very quiet. However, the lower units were banging quite loudly. I am not familiar with Mercury engines. Is this a normal noise for Mercury outboards? It has stainless steal props but I don't think that should matter. The lower units make a lot of noise without the engines in gear and with the engines in gear but not as much. A mechanic at the dealer where I may buy the boat said that it is just the play in the lower unit. Once it is in the water and there is a load on the prop, you won't hear that noise. That doesn't make any sense other than I agree when it is in the water I won't hear the noise, because it is in the water.
