i have a 1953 scott atwater 7.5 twin cylinder it was locked up and i tracked it down to the bottom end as the oil had leaked out and the forward and reverse gears were a bit rusty and loced up. I have since freed it up and cleaned it up and replaced the gasket and now i need to know what weight gear oil i need to use in it i have looked at a couple of sites but have not found an answer also is a 50 to 1 ratio correct for the fuel ? thanks again for all replies
