100ESL71C Johnson lower oil?
Timmyy
Hey all New here . So I got this motor been reading the form an seen that you can use SAE 80W-90 gear oil . No boat shops around me so I just want to make sure I can ust that oil. Reather green to boat motors tho. Great forum so far!!!!!!!!
tx1961whaler
Re: 100ESL71C Johnson lower oil?
Nope. The 1971 100hp is an electric shift gearcase. That gearcase needs Type C gear oil, not 85-90W
Timmyy
Ok thanx. Now were would I find Type C oil in a town with no boating supplys other than Walmart? Or is there an equivalent out there.
F_R
Get it here at iboats. http://www.iboats.com/Type-C-Gear-Oil/dm/*******.010372693--session_id.132169473--view_id.45019
Walmart MIGHT have it, but probably not. It will specifically say for electric shift gearcases. If you absolutely must, use Dexron Automatic Transmission Fluid till you can get the right stuff. BTW, at Evinrude and Johnson dealers Type C is now called "Premium Blend Gearcase Lube". Not to be confused with other brands called "Premium Blend". Not the same thing.
Timmyy
Checkes walmart an nothing so I will call NAPA with the part # an see what they come up with. Sux not having a boat shop close here in Alberta tho.
Timmyy
OK no oil close to me at all. Found a merc dealer do they have a compatible oil to use? Sales guy there didn't know for sure tho.
papasage
plain 10 weight oil will work .some standard shift ford trannies use automatic fluid and sone other standards b also .
Timmyy
Ok drive 4 Hours to pick up sum Type C . Drained the old oil filled the lower leg up run now she runs good. Sum oil now leakin out the prop. What is the seal in there like to change now?
