I have a 60s 10hp johnson the old stile pressurized tank is giveing me fitts not sure if something is dammaged it wont hold prime without the use of prime bulb advise of where to start to find my problem would be much app
make sure your lines are tight on carb and gas tank ,and make sure gas cover is tight, make sure the gasket on your gas tank is not leaking hope this helps
