Re: Squalling coming from my motor ????
I just got a chance to check things out. Had to reset my rockerarms to get the engine running right. She is now runningn perfect. When I first started her, i head the squalling, I looked at the belts and they were jumping because the water pump was not turning. before i had a chance to turn her off, the belts started spinning and the water put was turning. I let her idle for a while, which went fine. I turned her off and back on, no squallinng. did this several times with no issues. I let the boat run for about 30 min with no problem. Fires right up with no problems and no squalling.
Now my concern is why the water pump was stuck at first. Here is a little back story. First of last summer I took the boat out after dewinterizing. Ran the boat a bit and threw the impeller on the raw water pump. Out on the lake I pulled off the hoses and pulled the parts from the impeller. Hooked it back up and idled in and trailered her. The next day i put a new impeller in and ran it a bit, no problem other than having water in the oil. I took her home, drained the oil, fogged the cylinders and let her set until about a month ago. Last month checked the head, no problem. the problem was in teh exhaust riser gasket. Water was running back into my manifold. All of those issues are fixed. Should I worry that my water pump is going out?
