vicpresnal
- Apr 13, 2011
- 23
4.3 with moisture in crankcase, no rise in oil leve, no milky oil, only slight steaming coming out of oil fill cap on valve cover, houseboat that we do not log many hours, mainly short trips. at one time i had bad intake manifold gasket, lots of water in oil then, it cleaned up after 4-5 oil changes, 2 years later still have steaming, could this steaming be left over from the large ammounts of pudding in the crank or do I have another problem. I do have the old one piece mercrusienr exhasut manifold that I have heard is a problem. My question is could I put a T in the plug hole on the intake manifold and then add pvc valves to the valve covers, run that into the T. Would this set up help suck the moisture out of the crankcase. Currently, no pvc, only a line tune from the valve cover back to flame arrester , minimuim suction from the carb.. Help, my next optionis change the exhast manifolds, then head gaskets. Don't want to do this until a last resort. any suggestions?
