Hello folks
I'm restoring an old Paceship Sailboat and have a question about sealing the exposed fiberglass on the inside of the hull. The boat was waterlogged so I separated the hull and replaced the rotten stringers with plywood and epoxy/fiberglass cloth, and repaired the delaminated deck using foamcore and epoxy/fiberglass. My question now is should I seal the exposed old fiberglass areas and if so with what? I have already painted the stringers and sprayed CSM with epoxy paint but I'm about to reassemble the top of the hull back to the bottom half and am considering epoxy painting the underside of the upper part of the hull (deck).
