i have a 15 hp 83 mont wards and it will start 2nd pull run really good for 5 min sometimes and then die..new fuel lines.. fuel pump working..while idling it will pop.... rev low then rev back up.... will idle only for a few min in neutral..same in if i run it in forward gear...fuel comes out of carb in front right below butterfly when pumping primer bulb when i go to start engine....carb issue?...
just took her out on my 12ft fiberglass w me and gf and backup trolling motor...ran like a bat out of hell..........planed in 4 sec..gulf a little choppy tho...
