I was on the lake yesterday and started off running at crusing speed (22 mph) to my first fishing spot. We trolled there for a while at 3 to 4 mph then ran to the other side of the lake some of that at WOT (28 mph). We trolled that area, then moved again at crusing speed. Trolled that area for about 30 minutes then decided to head back to one last spot before calling it a day. We ran at crusing speed for about 1/4 mile then WOT for about 2 miles. When I slowed down at the last spot and started to idle in the the area, the motor sputtered and died. I checked and the motor didn't seem like it was overheated but it was hard to get it to shift into neutral. Once I got it into neutral I got it to start once after 5 pulls (This is a one pull to start motor) it ran for about 5 seconds at medium throttle but died when I tried to lower it to idle.
It was only about 400 yards from the boat ramp so I used the trolling motor to get there. Once there I tried again. This time I pulled on it about 10 times to no avail. I set it at full throttle and it fired up but once I went back to idle it died.
Sorry for the long drawn out explaination. Any suggestions on where to start would be appreciated.
