Hi folks!
Got an Evinrude 1992 v4 90hp and had it for a couple of years. It?s always started but really never reved out as it should. Max rpm is around 4400.
After winter conservation and impeller change did I notice quite a lot of water in the exhaust. See http://www.youtube.com/watch?v=3FrLpdTW9tI&feature=youtu.be.
The engine runs as before but maybe idles a bit more rough. Been browsing the forum and talked to a mechanic. The mech said that it's most likely some problem with the inner exhaust plate (head gasket blown are quite rare). He recommended me lookin for a new motor...
Have a few questions:
1. Seems like quite a lot of water comin through - is it dangerous to run the motor?
2. Whats your opinion on the most likely reason?
3. Got a service manual and in that is the outer and inner exhaust plate accessible if you remove the power head. When I look at my motor it looks like it could be removed without lifting the whole powerhead - true?
I suspect I always had some leakage and that may have affected the top rev and that it got worse with the new impeller (and higher pressure). I like this motor and would really like to give it a go.
Cheers
/Mikael
Cheers
/Mikael
