I've begun restoration project on an '89 Four Winns 210. After being stumped removing the Throttle Assembly, I spent the last week reading in the forums about how to remove it. All the conversations revolved around an set screw removed by and allen wrench when the throttle was in the full reverse position. I could find no such screw on my assembly.
I'll post my experience to help anyone else struggling with this.
Since I was in the middle of a restoration I had already the side panel that the assembly is attached to. I removed all of the accessible screws from the gear box on the back side of that panel. Unfortunately one screw head (in the bottom black portion of the gear box) was positioned against the panel. That required me to create slack in the cables, move the panel towards the back of the boat and spin the gear box 180 deg. so that I could access the screw through a cavity in the panel. Once that screw was out, the box came apart.
At that point I removed the first of 2 Retaining Rings. Behind that ring, a plate, plastic washer piece and spring came loose. Next I removed the second retaining ring. At that point the throttle handle finally came loose!!!
It's possible that I missed something, and there was an easier way to accomplish this. If that's the case feel free to let me know so that people in the future will better understand the process.
Hope this helps someone. I've received a ton of valuable information from this forum!
Micah
Micah
