1996 Force 75 hp single carb. In idle the tack shows about 600 rpm when i slip it into gear it wants to die, to make idle adjustment do i remove plastic end of idle rod from carb and adjust it out to make rod longer then snap it back on to carb and tighten jam nut? Hope this makes some s?ance. Thanks
