88 Four Winns , 4.3 Chevy , Cobra outdrive , low hours.
Sorry, this will be long read but didn't want to miss anything that might be important.
Thanks in advance!
Bought boat without upper half of outdrive. Previous owner changed fluid, filled from top, locked it up.
Bought used upper half and had strange problem. There was a rubber expansion plug I had to remove from the upper half that blocked water flow. Removed freeze style plug from side of outdrive (behind cobra logo) then replaced freeze (expansion) plug.
Boat ran cool on hose with muffs. First time on lake it got hot under power. Shut it down to idle in neutral figuring would cool off faster if I kept the water flowing. Stayed hot. Bumped idle up from 800 or so (what ever low idle was) to around 1300 and it cooled down.
There was a hairline crack in the plastic impeller housing so I ordered kit with housing, cage, impeller, gaskets. Winterized for season.
Installed new impeller kit last week and fired it up on the muffs. Great so far.
With a little more reading decided to check a few more possibilities for flow blockage. Also, new T-stat went in last fall. Pulled water into stat housing and started with muffs on, water flowing. Pulled impeller housing and stuck garden hose in inlet house that connects to stat and water flowed out the outdrive at the impeller housing area. Re-installed the impeller, put muffs back on and fired it up. Exhaust risers got too hot to touch so I knew something was wrong. My boy said "that supposed to be smoking?"
Shut it down and found new plastic impeller housing melted.
No water coming up to the impeller from the muffs (?)
Pulled impeller housing (with glove on). Put garden hose down the opening that water comes up from the intake openings in the lower and water flowed out. Put muffs back on and water did Not flow up to impeller area. Goes one direction but not the other. Well, doesn't go the way I need it to go.
What is in there that could be blocking the flow? Why was it fine a few days ago? I was going to put it in the lake today to see if it got hot again under power. Was thinking all kinds of things like blockage in ps cooler, blocked exhaust manifolds/risers, etc.
Maybe my only problem (looks like possibly intermittent) is a blockage in my lower unit. Possibly had nothing to do with being under power but just happened that time last fall and not on the muffs last fall just like it was fine a week ago but not today.
Didn't want to drain lower and pull yet. Hoped for some ideas on what to look for. Common?
Thanks in advance!
