Hi,
I've converted my engine from RWC to FWC with a San Juan kit. The original RWC had water routed to the bottom of the exhaust manifolds and to the risers. The FWC kit has the water routed to the bottom of the exhaust manifold only, the riser inlets are plugged by design of the kit.
My question is about the stainless plate between the riser and manifold, it defintely plays a role in the cooling, is it still needed if the the water is only coming in from the bottom of the manifold?
Thanks in advance,
A.V.
Thanks in advance,
A.V.
