I have a 2002 merc outboard 90hp. So The wife and I were out fishing yesterday. We were changing spots when the throttle got stuck, it is always stiff hard to put in in and out of gear. So i forced it into gear i heard and felt a pop. The throttle went forward with the boat not really going anywhere. So I popped the plastic top off the shifter box. I moved the shifter up and down and nothing so I hit the neutral button well, what a mistake. I could not get it out on neutral. So I moved the shifter up and down and a few broken metal pieces worked there way out. Would it be the control box or the cable? Should I replace the cable and control box?
