Re: OMC 400 Series Outdrive
To date this is eveything I have tried to cure my customer's pontoon from jumping or bumping while underway in forward gear. It does not seem to occur at idle in forward gear (650RPM) nor does it do it in reverse at any RPM. From 1000 RPM to 2000 RPM the bump occurs every 3-4 minutes. As RPM increases, the regularity increases. As engine temperature increases the frequency increases. The engine literaly "jumps". The engine never goes above 162'. When the jump or bump, whatever we want to call it, happens there is absolutely no change in RPM, neither increase nor decrease. It really feels like the drive has hit something.<br /><br />The stern drive has been removed and both the intermediate and lower gear cases disassembled and inspected. There was no damage visable to any splined shafts, gears, and/or clutch and corresponding engagement points on the forward and reverse gears. There were no metal shavings in the gear lube nor collected on the magnetic pick-up drain plug. Both ball gears are intact with very little wear for 20+ year old boat. The upper housing driveshaft was removed, the splines inspected with no wear or slipage evident.<br /><br />The shift cable was properly adjusted after the stern drive was removed and the disassembly process completed. During one test drive the shift cable was disconnected from the converter housing and shifting was done by hand, maintaining pressure on the shift arm. When the bump occurred with my hand on the shift arm of the converter housing there was no slack in the core wires and no indication of the clutch slipping.<br /><br />Also tried with unsuccessful results:<br />Car rebuild<br />New fuel pump installed<br />Fuel lines from the fuel tank to the carb checked for kinks and in some locations new fuel lines installed.<br />New points, condensor, rotor, distributor cap installed.<br />Dwell set at 34'<br />New plug wires installed<br />Timing set at 4' BTDC.<br />New water pump installed in intermediate housing<br />New thermostat installed.<br />(NOTE: not all of the above were performed as a direct result of the bump/jump conditions, but because the customer insists on using cheap gas and was experencing vapor lock at times.)<br /><br />Also tried:<br />Disconnecting the shift interruptor swith.<br />Disconnecting the tilt motor<br />These also failed to correct the problem.<br /><br />I am out of ideas!!!!!!
