Well tryed to start my boat for the first time this year and "nope" Its a 4.3l omc 1988, i used my continuity test light and im getting power from the igntion to the coil, but when i checked to see if any spark was comming from plug wires "nothing" i then put the test light on the end of the coil wire and it was real dim when i turned the motor over. I swaped the coil out and still nothing. So i guess it leaves me to the points and condensor?? What do you all think? I have to order the points, so for a few buck i might as well eliminate that. any pointers will help thank guys..
