Re: Bottom Paint?
There you have it. YD's paint is hard, mine ablative.
Actually.. VC-17 is not a 'hard' bottom paint
.. ( Im not talking VC Offshore .. but VC-17M ).
VC-17M is more like a bottom 'coating'..not a bottom Paint like you would think..
When most of us say "bottom paint" or "AF paint" we bring up ideas of a gallon of nasty paint that needs a paddle mixer and someone with a strong arm(s) to get that gallon from point A to point B ( Heavy Paint )..
VC-17 does not even come in Gallons. It ONLY comes in Quart sizes ..
So while some may buy a gallon or three of regular BP .. some buy just 2-4 qts. of VC-17 ..
Why ??
Because VC-17M is Water thin..you apply with a Foam roller..you mix per/qt ..not a gallon.
This is not 'regular' bottom paint.. its a 'coating' .. and a Very good one at that
I have done Years of bottom washings when Haul-out comes to Michigan..when the boats get lifted out of the water .. we all scramble to the pressure washer that is closest to the VC bottom
.. I am not kidding.. It does not matter if its a 45' with VC..or a 20' with CSC .. we all want that 45'er ..
Just look into the VC is all I am suggesting..after that .. its up to you..
YD.
