Re: Flat primer bulb
I did shut the gas off at the tank last thursday night ,the next morning the bulb was almost flat.somehow fuel is getting into the engine and fouling out the plugs.i'm not using the oil injection side of the pump just the gas side, i mix my oil & gas after a 2,800.00 repair on this engine because of the vro failure.i'm wondering if the fuel could be entering the engine through the pulse limiter valve, if the diaphragm in the fuel pump is bad, somehow the fuel is being siphon out of the tank and getting into the engine.
