shadypup99
- Apr 3, 2012
- 9
Ok, I recently bought a 84 champion bass boat, only 500 bucks. So it has some minor things wrong, that are easy to fix. But the main thing is the outboard is supposedly bad. It also was missing the fuel tank, oil tank, and the controls. I have bought a 703 yamaha control, and figured out how to hook it up. The motor started up pretty easy with a squirt bottle full of mixed gas. So I got new fuel line and managed to hook it to a 5 gallon can and it runs pretty good. It is stuck in limp mode. I figured out that one of the temp sensor is bad but havn't replaced it yet. I also noticed that there was no water coming out of the tell tail. I figured out that the hose was clogged and fixed that, and then found that the "popit" valve was stuck, fixed that. So now I have water coming out like its supposed to, even with the motor off. But I took one of the thermostats out, and no water is getting up there. So here is the question, is there any way to tell if the water pump is working, from what I have said or anything else I can check? I dont want to go into replacing the pump if I need to buy a whole rebuild kit and clean out a bunch of water passage ways.
Kenny
Kenny
