onesNzeros
- Jul 27, 2011
- 15
I believe this is my first post in this forum. Mostly been reading and learning for the past few months. I've already learned a lot from you guys. Thanks!
I pulled my outdrive this weekend for my first bellows job. Replaced the bellows, gimble bearing and the lower shift cable. I got everything back together yesterday evening and now I can't shift out of forward. Initially when I tried shifting from the forward position it was in from removing the outdrive, it wouldn't move past the neutral position. I thought I just had some cable adjustments that needed to be done. I've adjusted the new cable for a while and can go from the forward position to the reverse position, but the shift interrupt switch engages in one position or the other depending on where the adjustment in the cable is done. However, regardless of my adjustments, the outdrive stays in forward.
My current theory is that the shift slide in the bellhousing slipped off the lever while we were mounting the outdrive back on. Is there anything else that I should be looking for here? Something else that could be wrong?
Oh yeah, this is on an '84 Sea Arrow with an Alpha 1 outdrive.
