tailwind 67
- Jun 24, 2005
- 34
I just installed a new impeller in to my sea water pump for a Mercruiser 5.7 with a Bravo II stern drive. The pump housing has one bolt that threads into the front part of the housing, the remaining bolts that hold the housing together have nuts. The bracket that mounts to the block is directly under the nuts, and covers the threaded hole for that one bolt.
Is there any reason in particular that this bolt does not have a nut? The front housing threaded hole is stripped. I tried running a tap through it, but the soft aluminum threads are weakened, and without going to a larger size bolt which I don't know is possible, the best option would be to drill the engine mounting bracket and put a nut on this bolt like the other ones. Is there any problem you can foresee if I do this? There must have been a reason this one bolt did not have a nut because it looks like it is a straight forward job to drill and put a nut on it.
Thanks for any help you can provide.
