Wazzup4u2c
- Mar 14, 2012
- 13
1994 2 stroke johnson 25 electric start, started up fine, got me out on the water, i killed it to line up my rods, went to start it and the starter wouldnt make a sound, waited a few mins and messed witha few things, then it started to crank up again notmal, but my throttle shifter is stuck all the way low and wont raise up, its not letting me start the engine, the black rod the goes veryical from the throttle shifter up to the linkages under the flywheel wont rotate, the starter seems to be working fine, my phone is working so i can keep checking this every few mins thanks!
