2" bubble rise after laying CSM with Poly.
palace
Finshing deck in seat boxes and everything going quick. BUT I get this 2 inch bubble in middle after it cured. Hit it with a hammer and it is like steel, nothing. Battery tray might sit on it. So her you guys go, Will this make a big difference??
Chime in!
MountaineerMiner
Re: 2" bubble rise after laying CSM with Poly.
Post pics if you have any.
2" is a pretty big air bubble. Did you wet out, lay on the mat, saturate as needed, and roll out air pockets prior to it drying? If you are glassing over wood I would be concerned that that cavity will hold moisture and the wood will rot out faster.
If the rest of the glass job went fine I would just knock the bubble off with a flap wheel and re-lay that area.
Mike
Ayuh,.... It was probably Wet there, 'n it steamed up a bubble....
Grind it flush, 'n redo it...
palace
ground, flush and all redone no air pockets / bubbles. Thanks guys @bondo hand sand 80 or 50 grit between gel coat layers? QUOTE=Bond-o;3694556]Ayuh,.... It was probably Wet there, 'n it steamed up a bubble....
Grind it flush, 'n redo it...[/QUOTE]
