deputydawg
- Aug 29, 2004
- 1,607
I know I have seen this here before, but can't find it right now. How can I make a pressure tester for my drive? I am thinking of using the hose off of an old oil fill pump and a bicycle pump for the air supply. What is a good guage to use to monitor pressure? <br />Am losing oil somewhere, but no sign of oil drops on the ground. I'm thinking prop seal.<br />Also I found water in my drive. About 2 cups drained out of the bottom when I pulled the fill plug. This is not a surprise since this was a used drive that had been sitting for many years outside with no oil. Where would the most likely place be to look for the water intrusion into the lower drive unit? Would the bellows allow water in this part of the drive?<br />Almost forgot, it is a mercruiser older style drive, R I think is what it is called. The kind with the loop on the top cover. 165HP mercury inline 6.
