mine is a 1980 johnson 50hp to get to the bolt it is low on the powerhead underneath carbs. I had to remove starter motor (don't forget to disconnect battery first) to get access to it. my bolt was much smaller than 5/8 like 7/16 i think. anyhow if you have a helper move the linkage from forward to reverse while you stick your head under there you can see it move.
