ClassyBoat
- Feb 21, 2012
- 17
It’s a 1997 3.0lx Alpha one.
So I have been trying to troubleshoot what seems to be a fuel issue with a bout I boat a month ago. I was having trouble idling. It sometimes (most of the time)it will die if left to idle when on the water. Doesn’t do it as much on muff at home. It also seems to bog down till the engine cuts off this happens when I press the throttle. I have replaced the fuel water separator and looked at the inline fuel filter(The one that in the carb inlet) which is fine. Last night I ran a fuel pressure test multiple times. Its stays right at 5 or 6. Even when its dying. That should mean it’s not the fuel pump right? Could it still be bad gas? This is the first tank of gas of the season. My brother thought about running some SeaFoam through it. I will try that tonight. What do you guys think it could be? Is it the Carb? Or could it be a throttle issue. I like to do things myself but doubt I can repair a carb which can get expensive for someone else to rebuild.
I have Some video uploading now.
Temp Video location
Temp Video location
