Ok I have a 1989 MerCruiser 2.5L motor..
I took the boat out last summer and after about 10 minutes of running a milky white foam started shooting out of the top of the motor (I had the flame arrester off as I was adjusting the carb which always runs rough unless I manually hold the choke 3/4 closed, but save that for a different post)
SO I figured either the block was cracked or head gasket went..I was surprised to find zero water in the oil pan and oil was clean as a whistle. I didnt take the boat out again and when I went to winterize it, i found winterizing anti-freeze still in the motor AFTER I had it in the water earlier in the year...I wonder if the thermostat is bad and the antifreeze never got flushed out, and if this has anything to do with the stuff spewing out of the top after 10 minutes of running.
any idea what I should be looking at first before I start ordering parts?
