mickab
- Mar 5, 2012
- 53
hi again, few more questions about this motor. in an earlier post i had cooling issues but checked everything and it will start to pee just above idle, and the stream gets stronger with higher rpms. now a new problem. when i hammer down on it to bring the boat up on plane it boggs for a few then finally takes off. runs like a champ at WOT. but on take off it boggs bad, it doesent dieor anything. if i go back to idle it will do that just fine. im thinking carbs and spark plugs, but on a 70 hp merc 92 model on my other boat it did basiclly the same thing and it was a combination of the switch box and stator. so again any advice would be a very big help. have ordered new gasket kits and plugs, going to throw that at it tonight.
