Hi guys, I really need some advice here!
I'm having an intermittent problem with my dash switches. It started with the blower not working...now it's hit or miss with everything on the dash (strictly the switches, not the speedometer, fuel, oil, etc, those all work fine).
Last week I troubleshot the blower, getting 12vdc to the switches, ohmed the yellow wire from the switch to the blower and is good. Ohmed the black wire from the blower to ground, that too is good. Swapped the wires with the bilge switch and blower didn't work still, so thought I ruled out a faulty switch. Cleaned harness connection by steering wheel.
Now, when I go out and everything is cool and has not been running, all switches work as intented. Today, I started to the boat (switches working before I started it) and as you can see from the pics below, when it's not working properly, I press CT LT switch and the bilge, blower, and CT LT all light up, but nothing turns on. Also, the other pic shows the horn being pressed and the same 3 lights lighting up, but no horn (blower, lights, or bilge either).
Went out about 4 hours later and everything was working fine again. I started thinking this was a blower wiring problem, but am thinking it is def. something else! Does anyone have schematics for this or any suggestions? Should I go buy some new switches and pop those in?
I have a 1995 Mariah Talari 180 (w/ a 3.0L LX Mercruiser). HULL ID MAB10038F595 if that helps.
I had the boat out for the first time since I purchased it and I was unable to use the blower, bilge pump, etc and I won't take it out until I get this nailed down.
Thank You!
-Tim
Thank You!
-Tim
