80 hp boggs out when in gear
trapp
can anyone throw me some ideas of why my 80 hp would bogg out when in gear. ran good a couple times last week. its a 1982..
CharlieB
Re: 80 hp boggs out when in gear
Low compression on one cyl, weak spark on one or more cyls, dirty carbs?
Systematic troubleshoot your problem, start with a simple compression test, when all cyls are close to the same then check for a hot blue arc across a 7/16 inch gap. If that is fine then order carb rebuild kits and start cleaning carbs, but ONLY after ensuring compression and ignition are up to 'snuff.
trapp
thanks charlie.. i'm gonna try that..
