This motor is new to me and i have been reading up to sort out a few things. There have been many things wrong with the motor after replacing the magnets in the flywheel most of the issues were resolved and besides a rough idle it performs well. The tacho has been working intermittently and generaly there is only 12volts on the gauge so i figure the rectifier. The only issue is to do the test as suggested in the forum i can't make sense of the wiring on the terminal block. It appears to me that the grey wire from the rectifier is attached to twin brown wires. There is a red wire on terminal 4 not attached to anything. The Purple 12v vcd lead on terminal 5 looks like it is attached to a grey wire which should be the tacho. I have attached a photo of it so you can see. When i took the grey wire and screwed it on to terminal 1 i blew the 35amp (i think) fuse in the motor. Can anyone make any sense of the wiring.
Regards
Paul
Regards
Paul
