Hello guys,
I am new here and i really can use your help right now !
The sensor of the left 3 cylinders, has been broken off, i tried to get it out by flushing but that won't work.
I've already taken off the part where the waterpump is fitted, even before the sensor broke...
But still no sensor
I've tried flushing it from the waterpump side, even through the place where the thermostat is located, but still nothing...
Do you guys have a suggestion?
Then part that is in the cooling system somewhere is 1cm long and about 6mm high.
It is made from plastic, not metal.
Maybe someone has a circuit of the cooling system?
Pls help me with this one !
Greetz,
Rob
But still no sensor
Greetz,
Rob
