Hello All, I am new to the forum but figured I could find some good information here. I am in the process of rebuilding an 1990 Evinrude 88spl. This is my first two stroke rebuild. I have started to reassemble the engine and I have the pistons and crankshaft back in. Still have standard bore just honed the cylinders and reused old pistons. I have new rings but reused the old bearings. My problem is when I turn the crank over by hand everthing rotates smoothly with no binding or hard spots but there is a poping noise. It is four different pops, and they are consistant with each rotation. I am worried that it may be a bad bearing or a problem with the rings. Or is this normal for a 2 stroke? Possibly just the sound of the rings riding over the intake ports? I am just use to a 4 stroke rotating assembly not making any noise when you turn it over by hand. Does anyone have an knowledge of this? Thanks for the help.
