5 o'clock Houseboat
- Mar 26, 2012
- 7
I have an 88 merc 165 in a bowrider and it seems ot have a gaas preheater between the fuel pump and the carb. There is a 1.25 inn ch rubber hose labelled heater and it is over a thin gas line. At one end it takes hot water from the rear of the head and at the other end it has a fitting to take water froom the bottom of this hose to the water line going out to the outdrive. the fitting at the outbound end is a 3 inch copper line with a 1/4 inch nipple onn it. On mine the nipple broke off and it had been sodlered. Should it be soldered or is there a part that has it made as one unit without the solder joint? I am afraid tht if I solder it that it will break again.
