prop that is on the boat is worn so bad i can't get info off it.
D dvx216 Cadet Joined Sep 11, 2011 Messages 18 Mar 25, 2012 #1 prop that is on the boat is worn so bad i can't get info off it.
sutor623 Rear Admiral Joined May 23, 2011 Messages 4,087 Mar 25, 2012 #2 Re: prop size 1988 weekender 5.7 260 Hp dvx216 said: prop that is on the boat is worn so bad i can't get info off it. Click to expand... Prop shop is your only hope, theyll be able to measure it.
sutor623 Rear Admiral Joined May 23, 2011 Messages 4,087 Mar 25, 2012 #3 Re: prop size 1988 weekender 5.7 260 Hp If you can give me your WOT Rpms, speed at WOT, and gear ratio of lower unit I can guesstimate your prop slip and figure out closely what pitch you are running.
