Hey guys,
I'm having a starting problem and my gut tells me it's the fuel pump but not 100% sure.
Here is my scenario:
When I spray starting fluid in the carb the engine starts and then dies 3-4 seconds later. Crank on the engine, everything is popping but engine is not running.
Cap, rotor, plugs all look good. Changed fuel filter, and gas that was in the filter was dirty. Fresh gas in tank.
Now when cranking the engine, inside the carb I didn't see any gas spraying in.. Problem / cause??
The new fuel filter had fuel in it so I'm a little stumped.
Bad fuel pump?
Carb?
Thanks..
Bad fuel pump?
Carb?
Thanks..
