boatasticaldave
- Mar 19, 2012
- 9
I'm going through the motions involved in troubleshooting steering problems. Disconnecting steering cable to see if problem resolves itself, checking fluid levels,etc etc. I'm not through going through all these steps so a definitive answer has yet to be found. But i had a question while i'm going through this... I believe that, when the engine is running, that when looking into the power steering pump reservoir, i should see some swirling of the fluid. This is usually the case in automotive applications so i am assuming it should be no different here. My point is, that i do not see any swirling, which leads me to believe the pump is most likely the issue. Although i am continuing to check the other items involved in the steering system, i wanted to get some opinion on the swirling issue.
Merc I/O 165
Hard to steer,
No difference if engine is running or not.
Merc I/O 165
Hard to steer,
