justinjohnsonh20
- Dec 15, 2011
- 28
After in use all day I put the boat in reverse and it started popping/clinking sound real loud. I put it in forward and the noise went away. Later that day when I loaded the boat it didn't make the noise in reverse. Did the gears in my foot break/grind off? It was fully in gear when it was making this noise. Is this a linkage problem or should I pull the foot off and inspect the gears? Thanks for your help and info.
