gilligan12
- Mar 24, 2012
- 18
Mercury 2000 2 cycle 135HP OB with Commander 3000 Controller panel mount.
My 1st boat, just purchased from a trusting old salt who hasent moved the boat in 2 seasons.
Motor starts adn can push idle to 3000 RPM or higher (had it in the water, but spent the afternoon dockside due to shift issue).
When I pull the neutral lock up, cant seem to push into gear unless you really lean on it hard. Either direction .
Orinially susspected the controller and cables, so I took controller apart and cleaned and lubed. When cables disconnected at the controller , controller moves fine.
Connected cables back on the controller , seems to shift a little easier but still way too hard to controll speed effectivly.
Susspected cables, to test I disconnected both shifter and throttle on engine side.
Controller moves easy. Thinking this is a valid troubleshooting test but Im new and could use some guidence.
Im hoping there is nothing wrong with lower unit.
Motor has 85 hrs on it. I changed the LU oil before running. It was black, but no water nor pieces of metal. Not much glitter either.
Any suggestions?
Should the leaver that the shifter linkage connects too (center of OB) move easily?? It doesnt...
thanks
Any suggestions?
thanks
