bobgritz
- Sep 22, 2009
- 185
This motor was owned by a FD and I doubt it was ever used. It is spotless under the cowling (I hate to subject it to any use, it belongs in Outboard Museum). It runs like a swiss watch at upper RPMs but at idle it stalls out. I took carb apart (didn't take off metal caps) but I did soak it for a long time and thoroughly blew it out. After re-installing, it still doesn't want to idle. If I pull the choke to about 1/3 it idles very well but as soon as you push the choke in you need to rev it up to keep it running. I've adjusted the needle valve from zero to 4 turns and it runs best in the 1 1/2 range.
Could the float be out of adjustment? I did the usual 'level with housing' adjustment but I was wondereing if it can be adjusted to compensate for the engines need for a more 'rich' mixture! If the flow of fuel is based upon a venturi effect perhaps if the float allowed more gas in the bowl, the gas would set higher in the bowl and would be more easily sucked up even thought there is lower vacuum at lower idle.
