In spring 2011, I had a Mercury remanufactured 4.3L V6 engine installed in my 20' Chaparral. It was a complete engine (minus intake and carb) that was fitted up with all the accessories from the original engine. A new intake and original carb were placed on the new engine. With the new engine, I have lost 3 to 5 mph off the top end. The mechanic says that everything is adjusted properly and that it "is what it is". It seems odd to me that a remanufactured motor would produce 10% less top end than an engine that needed to be replaced (due to a bent crank that I didn't know about when I bought the boat - argh!). Although I can't quote specific numbers on rpm, the wot is well within the range for the engine and the engine runs fine. No changes were made to the prop or outdrive (except new bellows and gimbal bearing).
I am wondering if I should accept the "it is what it is" diagnosis or if there is something more I can check. I don't know much about boats but I have turned a few wrenches on car/truck engines. So, I can check most anything that doesn't require special tools, etc. Should I be looking at timing or a carb adjustment (carbs can be tricky). It goes without saying but I will say it anyway - thanks in advance for any suggestions.
Here are the Volvo Penta numbers:
Engine - 4.3GL PEFS (4012004849), Outdrive - SX-M 1 79 (4112094763), Transom - SX-MLT (4111633176)
