Re: 1964 Evinrude 60hp M#60453s S#E03855 wiring assistance or diagrams ?
Need to know..... Is there a gear shift lever on the port side of that engine or not?
On that model, there should be a good size plate on the front portion of the swivel bracket just below the carrying handle which has the model and serial number listed. Also, there may be a small quarter size core plug on the powerhead with those same numbers.
If a generator exists, it will be on the opposite the electric starter on the other side of the carburetor with a belt running from it to a pulley on top of the flywheel.
What do you need to know about the wiring?
