Helping a guy out with his motor. He has no spark on any of the cylinders. He replaced the power pack and still no spark. When I showed up I found the rectifier to be shorted. Power wire had most of the insulation cracked , probably shorted. Could shorted rectifier have taken out new pack?
DVA Stator voltage around 225 Volts. Allother DVA readings checked out, EXCEPT SENSOR WIRES TO GROUND. Each one only measured 22 volts. My data sheet shows 150-400 from ground on sensor wire 1-4.
DVA sensor wire to wire ohm values and voltage were in spec.
Thanks for an information.
