Re: Engine swap ?
Brian, I doubt it will fit easily, if "at all". Your 17 foot boat almost assuredly was NOT offered with a V-8 option. So therefore, you probably won't have the right mounting locations in the stringers. remember, your 3.0 uses a single mount in the front. All the V engines use two side mounts, attached to the stringers.
Also, you don't mention what year your 3.0 is, and what year the 5.0 with outdrive is. Alpha One Gen 2s came out in 1991ish. And they won't fit on the older Alpha One Transom plate/gimbal housing stuff.
As Don said, need more info.
But I am going to guess it's going to be difficult at best to swap them.
