Re: Contaminated gelcoat with striper
I need some help with my mako 19 proyect, by mistake I apply antifouling striper in a large part on one side of my boat (over the gel coat) How I can clean that contaminated area to prepare and paint that side of the boat?
You only want to Paint one side of the boat ?? or do you just want to get rid of the AF paint that is on that side ?
Wash with Acetone ?? really ?? I mean . .. we dont even know what AF paint is on there LOL ..
Acid wash with TB cleaner ?? .. Is this how you personally take off AF paint ? ..
Just Wondering ...
Kinda need a little bit more info on what BP ..
YD.
I should have read that better .. I naturally assumed that it was AF over gel. I dont know many times that someone put
Stripper beyond the waterline. I do know of some that put AF paint above the waterline
.. I just read it too fast and assumed he was talking about AF on his sides
.. DOH !! My bad.
he didnt say anything about AF paint.....just stripper....the AF paint is just a guess on your part.....i was refereing to the gellcoat alone
the poster asked how to remove the af stripper from gellcoat....what i posted will work with out harming the gellcoat
Yes It was premature on my part .. sorry again ..
I use the antifouling striper to remove the old paint in the boat ( that I think is IMROM) after remove the paint I realize that I can't use that product for remove paint. I clean the area but the surface still contaminated.
I am sorry for any language barriers that Might be going on in this thread ( there is no location that you put in when signing up ). ..
Are you trying to Remove a surface paint ( Imron ) ?? or are you trying to remove AF paint ??
Normally you can use soap and water to kinda remove acid stripper residuals .. but your still going to need to Sand and Prep your surface for New paint/primer to be applied.
I still (after I realized my fault on the OP) do not know what exactly your are trying to do..
Got some pics to post up ? ..
YD.
