Jeepman252
- Jul 19, 2008
- 2
I have the lower unit off to replace the water pump. I noticed what seems like excess play between the drive shaft and the prop shaft. When I hold the drive shaft from moving, I can turn the prop shaft about 80-85 degrees before feeling resistance on the drive shaft.
This seems excessive for any right angle drive. Is there a spec on this? Should I be concerned? I have never had metal shavings in the lower unit lube.
Thanks for your help!
